subaru baja wheels
tico0
calif
Will a set of wheels from a 2006 subaru baja fit my 1996 mazda B2300 SE ?
Simple answer....NO!!!
Totally different bolt pattern.
Subi is 5x100 mm.
Ford/Mazda is 5 x 4 1/2 or 114.3 mm.
If your looking for wheels that fit, Use the How To Tech in the top header bar. Go to wheels/tires, wheel guide. At the bottom there is a long list of what vehicles have the same bolt pattern,
although the backspacing and offset may be different.
Grumpaw
Thank you for your prompt reply, very helpful ,
My truck needs tires NOW (14'' stock) and want to swap to a bigger wheel 15'' or 16'' easier to find tires, more variety than 14''
Saw an ad, 06 ''subaru tires & wheels'' thought I got lucky if compatible with my truck,
Oh well I just have to keep looking !
Again thanks for your fast response.
Your 14 inch has the same bolt pattern as the Ranger/Mazda 15 inch wheels. Check the wheel/tire guide and look at the common wheels that fit.
Grumpaw
