MJ'sBlkBII
OK, here is the seemingly impossable feat I'm facing.
I want to come up with a 10" sub enclosure for the BII. Mine is a 2 seater with the rear seat bottoms removed and the uppers folded down for the lay flat configuration. It stays this way. I need an enclosure that WILL NOT impede the cargo area. I have debated trying to make the seat upper into a box but can't figure out how to still be able to have my gear or dog on top of it. Maybe a down firing set up? Also thought about reinstalling a seat bottom, leaving it in the tumble forward position, and making that into a box but I don't know what that would do for sound quality. Also don't know where I would put the amp. I am only looking to do a small addition for depth. I have a 300 watt kicker I can swap into my Ram, taking its amp out which is a tiny 300 watt ARC so it will not take up much more space. I could mount the amp on the side of the "box" if I came up with a set up using the seat lower. Any other ideas or pics of ingenious setups? Thanks!
