OK so you're sure it goes to the radiator first, not the external cooler first? I installed an in-line filter and the fluid can only flow one way through it, and I wanted to make sure I put it on the right way.
The hot trans fluid follows the same route that the antifreeze follows; from the transmission to the TOP of the radiator, then out of the bottom of the radiator and back to the transmission.
If you have a factory external cooler as well, then it would come from the transmission to the TOP of the radiator, out the bottom to the aux cooler, then to the transmission.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
