nutpantz
- Jun 21, 2012
My 90 bronco 2 has manual hubs.
I expect the are after the market.
I was checking my brakes today when I pulled off the tire, the hub came with it...
I was looking down at the hub suck in the rim...then I looked at the calliper and the splines and the long studs..
Then I pushed the hub from the rim and stuck it back in place..(went over the studs like a spacer)checked to see if it worked and went on with life...
Both sides are the same...
Is this normal?
What is the maintenance procedure for theses..
I am thinking I need to re grease after any water crossing as this cannot be sealed...
I'd there a better system?
Will these go on explorer axles when I upgrade?
Is this normal?
