hershy31469
- Apr 25, 2014
- Automatic
I have a 2003 Ranger Edge with a 3.0L. I just did a tune up on it. Replaced the spark plugs and wires, right after I did that the truck started acting up. I would barely do 50 mph. I've ruled out crossed wires, already replaced a vacuum line, rest the lines look fine. I took it to Autozone and put a tester on it, found out it needed a cam sensor. I did replace that too. After doing all that, it will now get up past 50 mph but runs as if it's misfiring. Also it idles pretty rough, idles around 800-900 rpm. At 50 mph its turning around 2000 rpm. Is that normal? I did check the gap on the plugs which are Autolite platinums. Did I end up getting bad wires or plugs? Coil pack bad? I don't know the history of this truck, only had it a couple months. Got it from a used car dealership, and yes the warranty is up.
