greenlander
The throttle on my 1994 Ranger (manual tran, 300,000 km) seems to "stick" open after I've taken my foot off the gas and/or pressed down on the clutch.
E.G.-- Downshifting, I'll press the clutch in and the engine will rev higher and higher, causing a sharp acceleration when I put the tran back in gear.
OR
The truck will accelerate even though my foot is off the gas.
Any ideas what the problem might be? I've found that by disconnecting and reattaching the battery whenever it becomes a problem seems to get me a few weeks of normal performance. I've done all the little stuff--new fuel filter, new air filter, new PCV valve, fuel injector cleaner, new idle-air control valve.
Thanks in advance.
OR
Thanks in advance.
