So my 96 B4000 Automatic is stuck in Neutral (or Drive?). I was pulling forward, then proceeded to shift into reverse to back up, and to my surprise, the truck wanted to go forward as if it was still in drive.
So I turn the truck off and try to shift into park, and after doing that, i was still able to push the truck as if it was in neutral or drive.
So now I cannot start it. What can be the problem?
**BTW**-- There is a "gap" between Neutral and drive. By gap, I mean that "click" that you get when changing through gears.
