stuck in gear?
Alohanigel
was driving down the highway with a broken clutch. i had to start it into first then jam it into other gears. while driving in 4th i hear a loud like snap and grinding noise which made me slow to a stop quickly. then stuck in gear i think moving the shifter into gear and the truck wont move. then tryed putting the shifter into neutral to move the truck more off the highway and it wouldnt move so i assume its stuck in gear problem for now is i have to tow it to my house before the county tows it. any ideas?
just need to get it into neutral for now. how can i do this?
Why were you driving with a broken clutch? It sounds like Major trans or clutch issue. You need to remove the drive shaft to tow it home.
