Mouldy
hey there,
1st I just want to say thanks to everyone on this site! you've helped me out of a couple of jams in the past.
1st post here so hopefully someone can help me solve this mess
been running in 4 hi for the last week or so as we got a huge dump of snow even switched to 4 lo a couple times working like a charm....until
yesterday ran the wife to work and went to switch to 2 hi (main roads are clear of snow now) lights went off but...
still in 4 hi...ok got home started lookin at stuff ..had some clicks ,ECM
light would go on and off after resetting ECM with switch ...tapping dash switches click click,,,no changes..then ecm would not reset..or the light wouldnt turn on again...started getting strange signs like dash lights come on then slowly dim...dash lights come on...(both hi and low lights) they go out when i depress clutch or press dash button..then come back on..all this stuff is intermitten ..some times they go on..sometimes they dont..just weird
i went to test the ecm using that great how to..and the ecm light dont light up at all... i have power ..and i have ground on the 8 pin pigtail
i found a used ecm for cheap and thought what the hell..buddy assured me it works...but same result
i have power at three of the wires at the dash switch (4 including the one that powers the dash light inside the switch from the parking light circuit)
and power at 2 of the conectors on the lower 5 wire plug on the front of the ECM. good power and ground on the 8 pin pigtail..
my ranger is a 91 with auto everything (electronic) dash buttons hubs tcase etc
hopefully this novel (sorry) has provided enough info
to me it feels like there is a short/open (bad ground or something) in there somewhere but what bugs me is that the ecm wont light up at all and im 99% sure i have 2 good ones ..i would move on to the switch diagnosis or even the motor but i seem to be stuck at the ECM
Thanks
Rob aka Mouldy
Thanks
Rob aka Mouldy
