Stuck camber sleeve in ball joint removal
av8r210
I am trying to remove the camber sleeve from the upper ball joint in my 84 Ranger. It still has the factory ball joints installed at 200K mi. After spraying BB Blaster for several days and trying to use chisels on either side for leverage, the camber sleeve will not budge. Can someone give me an idea on what will remove it? The Ford service manual is adamant about not using heat.
You might have to remove the knuckle first, that will release some of the tension on the sleeve.
