seh6183
- Oct 26, 2009
- Automatic
First of all hello! I am new to the forums as you can see. I just picked up a 1996 4x4 Ranger extended cab with the 4.0 and 5 speed. The truck is in great shape and has 170k on it.
I have already been through the tech section of the site and have noticed a few problems that my Ranger has (stuck door switch and such). Well when I first drove the truck I was sure that the clutch had air in the line because it was incredibly hard to get into gear from a dead stop. Then after driving it for 3 days I realized that if I push the clutch all the way in and wait about 5 seconds (to the point where you hear the throw out bearing stop making noise) it will go right into gear effortlessly. If I don't wait the 5 seconds and just step down and try to put it in gear, its like hitting a brick wall. I also read on here the the slave cylinders go out all the time on these trucks so ill have to take a look at that as well. I dont see any fluid anywhere but from what I understand the slave is in the tranny so... Anyways if anyone else's truck is doing the same thing please let me know what you think I should do.
Then Ill tell you about the couple other things I cant figure out
Thanks in advance!
