Strange problem
Bentsteele
Alabama
First of all, this forum has been a great resource. Lot's of knowledge here.
My problem started yesterday evening. I jumped in the truck and when I went to start it, everything just kinda shut down, like when a battery terminal is loose. I popped the hood thinking that's probably what it is, but by the time I got the hood propped up, I could hear the door chime, then it would quit, then start again, then quit. I turned the key to the ACC position and it kept doing it, and I noticed a clicking coming from under the dash, I moved the key to off, and it kept doing it. When I turned it to run, the door chimes and the clicking would quit and the idiot lights would come on, but when I moved the key to the start position, nada. It wouldn't do anything. I had to disconnect the battery to get the door chimes and the clicking to stop.
I replaced the ignition switch and it is still doing the same thing. After I got the lower trim panel off, I could tell where the clicking was coming from. It's some sort of small blue relay under the steering column. When I hook the battery back up, it starts clicking at a increasing pace, the my speakers start picking it up too. I can't find what this relay is in my Haynes manual. Anybody have any ideas?
I figured out that it is the flasher relay. Could that be what is causing the problems, or just a symptom?
Doo doo doo doo...doo doo doo doo... (twilight zone theme)
I'm gonna take a crack at this...
Do you think it's possible that the mechanism that turns everything off when you go to start the motor (to achieve maximum amperage) is cooked and now it thinks you're trying to start the truck when you're not, or something to that effect?
