Strange idling, finding codes.
josh_m
So my 1989 2.9L ranger idles very strangely. Between shifts rpms will stay up, and eventually drop down. If i rev the truck in neutral, rpms will stay up, then drop down. Now can i use codes to see whats causing the problem (IAC or TPS im assuming).
How do i get codes ? Its an OBD 1 truck so im assuming something to do with the CEL. Truck does not show a CEL when driving however. Also, is there an online "code book" anywhere ? Thanks TRS :headbang:
there is a list of code in the tech library here as well as how to get them read. if you get/borrow a chilton repair manual they are in there too.
getting codes is agood place to start
when was the last tune up?? you might have a broken return sping on the TPS..or a fraying throttle cable.
check the back side of the throttle plate for carbon build up
could be a vacuum leak too
