ok well along with the other minor problem i have with my truck. recently the tranny is giving me trouble, and its kinda hard to explain.
ok so last weekend when i went riding, my truck slipped from 3rd to overdrive (felt like it hit nuetral and then engaged smoothly). once it did that then the "overdrive off" light started blinking. when i got to a stop light i re-started the truck and the light shut off and then later down the road the exact same thing.
now after a good days ride when im driving home i dont have an overdrive light problem, but when im just cruising with the pedal barely in maintaining speed it starts slipping and my speed starts declining (like im in neutral). when it does this i push the pedal in deeper and once the pedal hits about half throttle you can feel it bang and engage. whether i hammer it to half throttle, or ease it there, it does the same thing.
another problem is that when i go into reverse it take about 3 seconds for it to engage.
other than that the truck drives fine it up/down shifts fine and it goes into drive the way it should. ive tried everything i can think of. i check the tranny fluid, tried shutting off overdrive, tried using cruise control, and there is no lights on my instroment panel showing a problem.
anybody have an idea on the problem? im trying you guys before i take it to a shop ($$$). im guessing its an electrical problem and not mechanical since it runs fine otherwise.
thanks,
cody
thanks,
cody
