stock to 4.56 gears in front ifs for 1995 4x4 ranger how to/ info?
4byRANGER
i bought the truck with 4.56 gears in the rear end for 33inch tires
but i cant use the 4x4 until i get 4.56 gears for the front/ right??(front drive shaft is out of the truck at the time)
to my understanding this should be true, so any helpful tips or anything i should know??
and PARTS!! who has the best but not the most expesive?
any help would be highly appreciated
thanks
4byranger (brett)
the gears alone will probably run you about $120.
changing gears is not a simple procedure. sure you can pop them in but they need to be properly set up otherwise they could be ruined in less than 50 miles. it is something best done by some one that knows what they are doing.
to save yourself some money, you can remove the front diff from your truck and take it to who ever you have set up your gears. it makes it much easier for them and makes it take much less time.
