Stock height with front bags
tlane3546
Basically I want to do air bags in the front on my 91. I want to keep a stock height. Has anyone done this? And how difficult? Do you have any pictures? No real reason other than my coils are getting bad. And it seems like it might be fun.
Thanks, Travis
Actually.....you can save a lot of headaches by replacing the OEM shocks with good quality Air-Adjustible Shocks....You can adjust the ride height by changing the air pressure in the shocks...piece of cake!
I currently have adjustible shocks on each wheel....truck rides like a Lincoln with minimum pressure/rides like a 4x4 on dirt roads with more pressure from the little $50 12vDC pump I keep in the cab---I have all 4 air lines routed into the cab under the dash so I don't have to get out to adjust the pressure!
Do you have any pictures of how you set it up? I do need new shocks....so maybe this is a better option. My V8 makes my 4 CYlinder springs sag a few inches and I dont wanna replace them if I dont have too.
