Still missing 2.5 four cyl
chuck ray
Replaced coilpack wires plugs fuel injectors.still has a miss.what to do next?
Check compression. Also check wires and connectors.
1) Agreed, check compression all four.
2) Determine exactly which cylinder it is by pulling 1 plug wire at a time.
3) If it misses at idle but not at 2500 rpm then might be compression.
4) Attach noid lights, new injectors won't do any good if no power. I learned this lesson in the past month because I did not have access to a noid test kit and now I know that they are cheap.
5) Check codes.
