Sticking EGR
ranger1999xlt
Iowa
I found this in the Tech Library! Does anyone have pictures for this so I can find the hose? Thanks
I recently had some trouble with the truck bucking sporadically, or when it rained. Three mechanics, 1 timing belt, 1 distributor, 1 set spark plugs, 1 set plug wires,1 cap, 1 rotor, 2, fuel pump relay switches, 1 computer relay switch, and 1 ink pen later, I finally got it fixed. The EGR valve was sticking. I removed the hose that comes out form the fuel injector to the valve and plugged it with an ink pen. Cleared it right up. I actually noticed it has a little more power too. Just trying to save you guys some trouble.
Found what?
I'm glad that solved your problem but, there is no hose from any of the fuel injectors to the EGR valve.
Well, I found the little section below of what I wrote! I found the section at the bottom of the thread in the Tech Library! Sorry for the confusion.
so was there a pic cause i have a 2.5 and it bucks on the highway
