liamkeough88
howdy,
Installed the extended pitman arm, got it aligned. and took for a test drive. Locked the hubs put it in 4wd and took a slow hard turn. Now the Aussie locker and the fresh fat rubber on the front obviously puts a lot of stress on the steering assembly but unexpectedly the steering wheel slipped and the now the wheel is crooked.
Any thoughts on what went loose?
I marked the pitman arm and gearbox with chalk to see if the splines were slipping but couldn't get it to do it again. Is the pitman arm supposed to slide all the way up on the gear box? I thought i got it all the way on but there is still a good half inch of spline showing.
.. in addition if you look here http://therangerstation.com/forums/showthread.php?t=100466
it may have something to do with it. Thought i got the steering shaft all straightened out but maybe is screwed up on the inside..
any ideas?
any ideas?
