steering columm change
avocat40
Hi
i will be changing m steering collumwith one out of a junkyard with the coded keys,mine still has thev keys snd works but when i out the other one inwill i have to reprogram theone from junkyard thanks:icon_bounceblue:
I would take your key cylinder out of the old column (since you said it works) and put it in the new one. It is easy to do and then you can use your old keys that work with PATS.
Yeah, just swap the ignition lock cylinders, it takes like 5 minutes.
ok thank you i ll get that done on weekend
