Zauna
- Sep 14, 2011
Hey Guys! Well im back unfortunately..more issues with the truck. Just replaced the Ignition module with a brand new one and installed some new spark plugs and wires...
Well seems like I have a new problem or maybe it was part of the old one I had. I had alrady noticed that the Ignition Cylinder kept on sticking on the On Position and was harder to turn each time, but it would start. Well today after trying to start the car I couldnt get the car to start, seemed like it was low on battery cause it acted like it wanted to start but wouldnt crank all the way. Changed the battery and it still wouldnt start. Pushed the car to get it to start and it finally did!
What do you guys think is causing the problem? Maybe the starter? Or could it be the Ignition Cylinder or the Ignition switch? I sprayed some wd40 in it and it seemed to help alot.
