codeJunkie
Hi Everyone,
I can't seem to get the starter on my 88 2.9L to stop walking when it cranks. It grinds like hell after the first start. It seems to be slipping away from the flywheel once the engine turns over since that is when I first notice the grinding.
If I get under the truck, loosen the bolts (which are snug as hell), shift the starter clockwise, and re-tighten everything, it will crank again beautifully for ONE start. Then its back to GGRRRrgrgrgrGRGRGrr.
I have replaced 5 starters, all from different stores (oreilly, advance, NAPA), new flywheel, new solenoid, new cables. The jackhole I bought the truck from put the wrong bolts in the bellhousing, which eventually stripped the threads. So I retapped them and I am using 10mm bolts, which now allow me to torque everything down to specs. The plate between the engine and bellhousing looks fine, it's not warped or anything.
Any ideas?
Any ideas?
