- Dec 6, 2009
- maplevalley WA
- Automatic
I think there's some confusion here...when you pull on the throttle, gas should spray into the carb from the bowl. You won't see gas coming from the fuel line when you pull on the throttle.okay so when pulling the throttle, im not seeing any gas coming out of the fuel line i have running to a glass. could that be a bad fuel line or pump?
well i done replaced that fuel pump had no real issues other than the bottom bolt being a pain to get too. still wont start i checked the voltage when i turn the key, i drops 8-10 volts but nothing happens, i suspect a bad ground or something of the sort? i plan on going over all the wiring to see if i can locate a faulty ground and or anything that is out of place. any suggestions would be awesome, Thanks for you help thus far. i really appreciate it!!
