- Sep 28, 2011
- St. Louis, MO area
- Automatic
I give up!
What is the proper wiring for a 98 Ford Ranger starter. I have 3 wires.
1. I know the small wire goes on the small nut (the "s" cable), which gets the signal when you turn the key.
2. I know the positive battery wire goes on the large nut furthest away from the starter itself.
3. The battery ground wire goes where? I am doing an engine swap, and I don't remember!
Insight would be greatly appreciated!
- I have seen posts about putting it on one of the starter mounting bolts, but the cable is not long enough to allow for that...
- The Ford Service Manual makes it look like it goes on third bolt (one closest to the actual starter) but I have been told that nothing goes on that bolt.
