Starter problems
Eli817
Firefighter
Beattyville
KY - USA
Other
F150
Vehicle
Drive
Stock
Total Drop
Stock
I have a 1993 4wd with a 4.0 and automatic, it had previously had an engine swap from a aerostar van so I am told, I do not know what model it was but the starter went out and I put a new one from advance on it. It was a two bolt 3224 but it started to turn it over and then just splns. The drive isn’t enguaging the flywheel and the flywheel is rubbing on the nosecone. Seems as if the nosecone isn’t long enough. I’ve tried three different starters! I’m stumped
The important part of the starters on these engines is the thin aluminum plate between the engine and the transmission. It needs to be the correct one, and the large hole that the starter fits into has to be tight to hold the starter in place. If you can loosen the starter bolts and move the starter back and forth in the hole, that is not good.
Can’t say if it’s the right one but the starter fits tight but it’s not thick enough to hold the starter back that far
Are you buying the Aerostar starter?
Yes it list the same starter
AFAIK the only different 4.0 starters are for manual or automatic... 3224 is the correct listing for a 4.0 OHV with automatic
The block plate being wrong would probably make the correct starter not fit at all. If it's an engine from an Aerostar, I wonder where they would've gotten the manual block plate. Manual Aerostars are pretty rare.
Has it had a working starter since the engine swap? If so do you still have that starter or was it turned in for a core? Can you get a picture of straight on into the opening for the starter? I'm guessing it just a language thing, but it does have a flexplate not flywheel right? If it's a flywheel I'm seriously wondering how the torque converter is bolted up.
I’ve pretty much ruled out the block plate since it had a working starter before, however the old one was traded in for a core. I wonder if there could have been differences in the flexplate but anything I can find says they should be the same. May just have to pull the engine.
If it had a working starter before it should be possible to make it work again...
I stumbled into a Facebook conversation yesterday. It's about 2.9 starters, but since the 4.0 is 2.9 evolved.
Starter problems
Starter problems
Starter problems
