IceBergeRanger12
Hey there.
Have a 1992 4.0L that's been having some starter issues. First problem I had was the truck started up fine but heard a clanking kind of noise coming from underneath. Shut off the ignition and the starter kept cranking. Turned ignition back on and was attempting to get it home and the clanking finally stopped while it was running. Starter disengaged finally. Got it home, shut it off and after that the starter would not spin. Starter relay still clicked on the fender wall but not juice. So figured I needed a new starter. Got a new one installed with a new relay just to be safe and the truck fires right up, however there's still that same clinking sound while it's running like the starter pinion isn't disengaged while the engine is running.
Don't see any adjustments that can really be made to how the starter sits and the flywheel teeth still look good. So is there some wiring that I can't think of that could be effecting that or does anyone just think I got a lemon of a new starter that won't retract it's gear?
Thanks
Thanks
