LoganP
I've got a '99 Ranger 4.0 5speed. The truck runs fine, but doesn't start cleanly. The engine has no problem starting, but I can hear grinding, I think from the starter. For some context, this was originally an automatic that was manual swapped at some point in its life by a previous owner. So far I've replaced the flywheel, clutch, slave cylinder, starter, starter wires and relay, and battery. Most of these needed to be replaced anyways, but the grinding started before I replaced everything. The previous flywheel teeth were worn down to the point the starter would free spin. I think the starter misaligned originally because the bellhousing was missing 3 of the top bolts. When I first started the truck after replacing the flywheel and starter, it started smoothly, but then later starter grinding again. Any troubleshooting to fix the grinding would be helpful.
