kunar
⭐Supporting Member
- Jun 10, 2003
- Toledo
- State - Country
- OH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Manual
my starter is fairly new, atleast new enough i shouldnt be having problems with it. probably close to a week ago it started sounding a little funny when i started my truck. over the next couple of days, it started to grind, but would still start the truck. i took it out and nothing looked out of line, so i sprayed it with some brake parts cleaner. i put it back in and it worked great. sounded smooth, no grinding. over the next couple of days, it started to grind worse and worse. once again i pulled the starter and sprayed it with starting fluid (i was at work and thats all i had) and once again it worked fine. 2 days later its grinding again. anybody have any ideas? i would rather not replace it, i plan to be doing a 4.0 clutch within about a month so i will be buying a new starter anyways. my next guess was gonna be to pull it out and hang it up in a bucket. drain a can of brake parts cleaner onto it in hopes that if i get it clean (really really clean) i wont have an issue.
