starter bolt
stockfornow
eau claire wi
just wondering if anyone else has the problem of the top bolt coming out of the starter on a 2.9. I replaced the starter 2 months ago and the top bolt was missing. today starter started acting up so i replaced the soleniad still not working right checked the starter and sure enough the top bolt was loose. any clue why the bolt won't stay tight?
havent had that problem, go get blue loctite. that will keep it from backing out, dont use the red loctite or you will have to heat the bolt to get it back out.
Never hears that happen before. Could always get a longer bolt and put a nut on the other side.
