So I assume the drum will no longer turn because shoes are tight?
Try pressing down on the e-brake pedal a few times, that will center the shoes.
Open the bleeder and have some one press the e-brake again, fluid should come out bleeder, then tighten bleeder, release e-brake pedal, you can try this by yourself since e-brake pedal will stay down.
This should relieve some pressure on the shoes.
Drums usually stick to the axle, the shoes are on springs so if drum is loose from axle you should be able to pull out on the drum and it will move even if shoes are tight against it, may not come off but it will move
So if drum is not moving it is rusted to the axle.
There used to be two threaded holes in drums just for this reason, you could use bolts in the holes to push drum away from axle.
If you don't have these then use a metal bar, like socket extension and hammer between the studs, try to break it loose, tap the side of the drum as well, tap.
DO NOT use a hammer directly on the drum between the studs, you will miss the drum and hit a stud, lol, and that will be a real pain to replace.
