Blu99XLT
Okay, before anyone suggests the cam synchro. I've done all the checks and determined that it's not that. I've replaced the belt, tension and idler pulleys and the dang thing still squeals! As I was under the hood the other day, I found that the belt is moving back and forth on the idler pulley causing the squeal. I sprayed a little WD-40 on the belt where it rides on the pulley and the squeal stopped until the WD-40 wore off and it started again. My question is: Could it be a "cheap" belt that is causing this?
Another question: The 3.0 seems to have a "miss". When I crank it, it sounds like it is out of time. I was told that it's not typical for the 3.0 to jump time since it has a chain. I have replaced the camshaft position sensor, which did not correct the problem. My next check will be the plugs and wires. Could it be as simple as that? Let me know what you guys think. I'm ready to drive my truck again. Thanks,
Jonathan
Jonathan
