Do you know the brand of the lift?
Yep.
IIRC, that's what Jim had on TRS1 at one point, and that has the same two holes on the one bracket.
Not the worst kit (coils aren't as rock-hard stiff as some), but close...
You'll need to lower your bumpstops when you install it, otherwise that bracket with the drop plate on it will bust a hole through your front differential housing (particularly if you have the D35).
I don't see a drop pitman arm in your pic, be sure to get one if you don't have that already.
