Springs!!
V8_power428@hotmail.com
Hey does any one know if there's a stock vehice out there that has a bolt in longer coil spring for the ranger???
early bronco/II.
coil spacers could also be an option.
are you looking for springs out of a stock vehical?
cause i know you can lift springs in a variety of lift heights for a ranger from all of the major suspension lift providers
its not worth doing it, aftermarket springs are way better. Any coil out of a different vehicle isnt gonna fit perfectly either.
right now im looking for a junkyard solution to my sagging springs eventually i'm going to buy a lift kit but i've lost probably 2 inches to sag the truck almost has 1/2 a million km's on it, the only benefit is i have tons of drop when going through holes but i bottom out over almost every bump! i was wondering if i could steal jeep cherokee springs or something similar to boost the truck back up
4.0 ranger or 91-94 Explorer coils.
sweet thanks alot for the help I think i'll just grab a set of exploder coils when i swap in a D35
