Spring Seat
dirtymike
knoxville TN
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Are the lower front spring seats and isolator on the 1987 XLT ranger 4X4 the same as the 1990-1992? cant seem to find mine at the local online store
It Seems that the spring seat are discontinued and so are the F2TZ-5A307. any help
Your best bet is to go to your local junk yard and get one from there, I believe the spring seat is the same on all Rangers from 86-97, I know they use the same spring from there but 93-97 use IFS and 86-92 has the ford TTB so you might only be able to get the spring seat from those years. Also here is forum about coil spring seats to level i know its not exactly what your looking for but it will give you a little more information Ford Ranger/Bronco II 2.9 liter Engines (therangerstation.com) .
LMC cant even get them. I am going to do the leveling with washers and one of the spring pearch's are split.
Ill put some pics up when i figure out how.
I found washers that measured 1.384 ID and 3.005 OD with galvanized coating. Is this the proper size. I Am trying to get it all together and do it in one day. Thanks
Im having trouble finding the spring seats and isolator. and body know where i can get them. 1987 ranger LWB 4X4 2.9L
