brokedown
- Apr 5, 2009
I have a complete duraspark ignition system from a '78 pinto coming this week and am looking for a 2150 non feedback carb to go with it. Once I get the other project out of the garage I will be pulling my '84 Ranger in to go through it front to back and top to bottom. Already have the buckets out of an '85 B2 EB set up with the correct brackets along with the center console, dash which is in VG condition, and all the trim. Still have a leak on the drivers side into the cab and will likely have to if not patch, replace the DS floor board due to a nice 2" hole in the sheetmetal right where the heal of my foot rests. I have driven it around the neighborhood just to see if there are any appearent issues and other than the need to drain all the fluids, do the front end 4x4 wheel bearings, and other maintenance, mechanically it seems good to go. Oh yea, I am going to have to put a clutch in it. The body is surprisingly good for an 84. Typical dents and dings, but not all that bad. Already have a new cat back exhaust, brakes, shocks, and tune up done. Lifters are adjusted eventhough when I get all the emission crap out I will most likely pull the covers and do them again.
Though I purchased it for something to work on and to use as a weekend LOWES truck, I am looking forward to having some fun with it. Will keep you posted as I start working on the beast here in a month or so as to the results of each step.
