427ford
Getting all the stuff together to replace the brackets on the rear leaf springs. Figured I'll do the spring bushings while I'm in there. Should I go with rubber replacment type bushings or Polyurethane. Suspension is stock (no lift). If you think urethane are the way to go.. where's a good source to get them?
Do the stock bushings come out with the old burn 'em and bang 'em out method like others I've done on other vehicles??
