Spindles
JohnnyTang
Renton Wa
2.9 V6
2" factory
If it jams force it, if it breaks it needs replacing anyways.
Hi
I was attempting to do a front brake job on my 87 STX. After pulling the rotors off I discovered the spindles on both sides are trash. I tried to source them locally but no luck. Rockauto only shows the nut and washer. Randy's ring and pinion shows the same parts. This is for a Dana 28. There has to be some place that sells new parts. I don't like the gamble on putting used parts.
Jeffs bronco graveyard?
I dunno. Its a 33yr old truck. You may have to start making compromises.
Sounds like a good reason to swap in a junkyard D35. Those parts were still available the last time I looked.
35 parts (and some 28) are on rockauto.
Anybody know if 35 spindles will fit on a 28 knuckle?
If not, as already said, get a 35 front end.
Nope, the ‘35 is bigger.
