spindle lift for 2wd?
DeMar03Edge
what company makes a 2wd spindle lift for rangers with torsion bar suspension? i ve seen one online a while back but cant seem to find it. it came with spindles and add a leafs and that it. other kits ive seen for 2wd with t-bar suspension is a complete kit that swaps the t-bar set up for coil overs. that not what im loon for though. thanx in advance
says 2001, but that doesnt matter right? thats alot chaper then the one i found a couple months ago too
shit, didnt see that about the 01, you will have to check your brake rotor size. Im not a A-arm ranger guy.So I dont know every in an out of them,and year breaks.But I do know they changed the front brake rotor size in certain years. I know you can swap brakes from year to year.so it will work for you, but you can gain pro's and con's both ways.
do some research, you may beable to find the info here, if not you will on dezertrangers.com
