Speedometer Wiring
Gokussj5okazu
Ok, I did a OBD1 swap into my 95 Ranger for my turbo build. Completely removed the OBD2 Ranger computer. The problem is, all of my gauges work except my Speedo because it's suppose to run through the ECM.
My plan is to run the Ranger ECM just to work the speedo. Problem is, I need to know what wire need to run for; Power, Ground, Ignition, VSS wires, and Speedo out.
Any help? I've looked and looked and cannot find the relevant wiring schematic for what I need.
ok year/make/model/engine of the computer in question?
THANK YOU! I've been trying to find this for 5 months, thank you very much.
here, these might help too:
it looks like the wire you need for your speedo is gy/bk which i'm pretty sure means grey wire with black stripe
and one last one that shows the vss:
i hope these tell you all you need to know
