JustME
By using my GPS I have found that my speedo is off (low) by 5mph at a reading of 30 mph (actual speed is 25 mph), 3 mph low at 40 mph but at 60 it is right on and stays right on til about 70 mph. I was told that there was a shift kit installed but the seller knew little more than that. Anyone? also I think there is an issue with a switch somewhere as my headlight/key in chime goes off any time I open the door, except when running, and yes the key is removed and lights are off. It will stop at times but I have no idea why. Tried to unplug the chime but just couldn't get to it as it is buried up in the dash. Just curious if someone might have an answer. Thanks.
