Speedo sensor on rear diff.
JohnAllen
Woodstock, GA
2.9 V6
6"
33x10.50r15
Just got another rear end to go in my Bronco 2 and did not realize that the donor rear end does not have the speedo sensor plug until I got back to the house. Is there a way to bypass this plug? I hope so because I don't have the money to go back and get another one.
Any help on this will be gratefully appreciated.
You just won't have rear ABS and may need to disable ABS light in dash
1989 used transmission/transfer case VSS for computer and cruise, rear axle VSS was only for Anti-lock brakes
So just cut the wire so it don't get hung on anyting and pull out the ABS light bulb in the dash?
Sure, or wire tie wire it with connector out of the way in case you(or the next guy) wants ABS back
