I swapped a 94 case into my 96 ranger. the 94 had a speedo cable, my 96 does not. Due to this, I just swapped the 96 speedo sensor into the 94 case. When I had the two cases out, I noticed they had different gears on the sensor. I want to say the 94 was a "17" and the 96 was a "19". I put the 94 gear on the 96 sensor and put the 96 sensor in the 94 case. Now I think my speedo is off.
I assume the numbers were the number of teeth, and the two teeth had the same pitch. If this is true, is there enough 'play' in the speedo sensor hole to rock a 19T instead of the 17T?
Any other solutions?
