speedo fix
Divh
bloomsburg PA
1949
has anyone used the JET Accu-Speed Control Units 50109 on a 1993 ford ranger and if so did it work i going to be changing gear ratios and tire size
You have a dual system on the '93
Speedometer/odometer is cable driven from trans or transfer case.
And there is a VSS(electronic speed sensor) on that connection at the trans/transfer, it is used by the computer, cruise and ABS only
So as far as I know you can change the gear on the cable end to match new wheel size and/or ratio.
Good read here on what gear to get: http://www.therangerstation.com/tech_library/Speedogear.shtml
The gear changes cable speed and VSS speed at the same time.
Everything you wanted to know about Ranger speedometers but were afraid to ask: http://www.therangerstation.com/tech_library/speedometer.shtml
I am old, most won't even get that paraphrase now, lol.
well thank you looks like i will just have to change the gear when the time comes
