Speedo correction on a 1995 Ranger.
Blackdog
Zillah Wa.
How can I correct the speedometer on my 95 Ranger? I put 33's on it and it reads 60 when I'm doing 70 MPH.
you need to get a new speedometer gear for the sender. if it is manual (and maybe auto), you need to pull the connector at the transmission and replace the gear with the proper one. Check on the tech pages for instructions. Speedogear
If it's like my 95 then the speedometer is triggered by the ring gear in the rear axle.
When I went to 31's I regeared to 4.56's and that took my speedo back to stock.
Allen
Went from stock 28" tires with 3.45 gears to 33"s. Changing axle gears to 4.10 was way better speedo recalibration than changing the speed drive gear or electronic sender. Costs more but alot more satisfying results.
