- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
Trying to put new seals in a flail mower gearbox that used to have FELT seals.... Needless to say, things are pretty pitted up.
I've found the correct replacement repair sleeve diameters, but they say DO NOT INSTALL OVER SPLINES.
So does this mean I can't go past or over splines? or does it just mean my final resting place can't be over a spline?
I've never used one of these things before.
Splines are pretty much the same diameter as the shaft, I guess I could take the palm sander and some aggressive sand paper to them to get it a little smaller...
