Thanks I know I have 4.10 gears because I replaced the 3.27 gears it came with.Gear calculator here: https://www.tciauto.com/speedometer-gear-calculator
you have a 7 tooth DRIVE gear
You need to know your rear axle ratio, most Rangers used 3.73 or 4.10
AXLE code can be found on drivers door build label, seen here: https://www.therangerstation.com/tech/ford-7-5-8-8-inch-axle-tag-door-codes/
Yes, the 4x4 transfer case uses the manual transmission speedo gear regardless of the transmission it's hooked to.I read somewhere that 4x4 use the same gears as a manual is this true
