Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Your 29 PSI fuel pressure seems low.
Have you changed the filter and pump?
Im not sure how you would diagnose an ECM issue in this situation.
@RonD
I’ve been going through the same levels of hell. At 53 years old I buy my 1st Ford ever, 94 Ranger 4.0 XLT a4ld A/T 76K original miles very neglected . My 49th vehicle. New tires, hubs-bearings-rotors, shocks , pads, calipers, New heads water pump, oill/coolant temp sensors and still wasnt running right. Then I replaced everything in the fuel pump all the way to the engine fuel pressure regulator on rail. Finally the truck was running and driving the best It has in two years. The only thing left was fuel injectors. So as I’m getting ready to move and my rear main decides it wants to start spewing oil. Friend and I dropped my trans installed rear main seal . I look in haynes and chiltons books and asked AI AFTER REINSTALLING TRANS, WHICH SIDE MY O2 SENSORS ARE SUPPOSED TO BE HOOKED UP TO IT ON HARNESS AND THEY ALL SAID RED TO DRIVER SIDE BLACK TO PASSENGER SIDE THEN AFTER THREE WEEKS OF GOING THROUGH CHECKING ALL VACUUM LEAKS, CHECKING FUEL RAIL I STARTED GETTING ERROR CODE 159 AND 171 SO THEN I GO AND CHANGE MY MAP SENSOR ((sorry all caps.. talk to text did thatI have a 94 ranger 4.0 2wd. Long time issue. Replaced many sensors. Timing issue? Vacuum leak? Ugh please help.
~112k miles
Symptoms, all in order:
Engine cold start: RPM’s always low at idle when cold. Always starts. Engine starts up fine, revs high for a few seconds and immediately drops idle very low, no tach but engine and truck visibly shakes, seems like it could die at any moment but never does. Exhaust sounds like a putter patter, Engine doesn’t rev up when cold at idle, even worse when a/c is on. Air idle valve is new. TPS, ECT, thermostat, spark plugs and wires, PCV, fuel injectors, upper intake gasket, o2 sensors, crankshaft position sensor, all <2 years old. MAF is 3 years old. Fuel rail pressure is 29 psi. Engine computer battles to regulate rpm, letting idle for a while, sometimes the engine rpm will shoot up randomly, but it tends to just idle super low mostly.
Taking off driving: I have decently loud exhaust, engine misfires while accelerating (muffled misfiring, not bangs or pops), when hot or cold (used to be intermittent misfire, now constant problem whether hot or cold). I live in FL so temp is never that cold.
Still driving: Seems like the engine won’t climb rpms, misfiring (not loud, chokes misfiring). Transmission short shifts, can’t climb rpms.
In 3rd gear, the gear seems long enough, once I reach a certain rpm, the engine springs to life like nothing is wrong. It’s misfires, has no power and won’t go anywhere even when floored and when it hits a certain rpm and everything seems normal and dandy. Sometimes I can’t hit a high enough rpm before it shifts, it seems like, and I can’t accelerate out of the problem. Trans maybe 30-35k miles on it. Transmission seems to work fine.
It’s done this most of the time I’ve had it, 3.5 years. Gotten way worse with my first full summer in hot hot FL.
Cleared all codes today, when misfiring after clearing codes while driving, the only code was 177 (rich left side).
Did check test with Innova for obd-1 immediately after driving. Only codes then were 136 and 172, lean right and lean left.
What the heck is going on?
Vacuum leak- if it is a vacuum leak, it’s not from vacuum hoses. I disconnected and plugged all vacuum lines, unless it’s the fuel pressure regulator leaking (new vacuum line to it). Seems doubtful, the regulator seems fine. Lower intake leak? Upper intake gasket is new. No audible hissing or other vacuum noises. Doesn’t seem to be oil or coolant in gas. Exhaust is clean, no smoke or vapor or anything. No clogged cats.
Why does my engine come to life at a certain rpm like nothing is wrong? Like you would think the engine could die at any moment, never does, then I hit a certain rpm and everything is just as good as it could be.
I’ve noticed as well when I get to 35-45 mph, before it was struggling all the time, the engine has a power jump that starts at higher rpms. Timing issue? PCM - CamshaftPS - motorcraft EDIS 6 (module behind front driver headlight basically).
Why would my truck not be able to accelerate and misfire, even when floored, then seemingly hit a certain RPM, and run amazingly?
