spark problem
superjasn
93 2.3L dual spark plugs... i have been chasing my tail with this no spark issue. has new wires, plugs, crank position sensor, and solenoid. ignition coils primary reads less than 1ohm, secondary right at 13k ohms.across all. had the ignition control module tested, it was good. getting power across the board. engine cranks all day with no spark.
tell me what to do. i am all ears.
i still think its the control module.
thanks much ahead of time
ECM? doesnt the crank sensor have an adjustment? if so, are you sure it is set? what does the code scan say?
thanks for the post and sorry i didnt reply sooner. i checked the ground. even went back and got the icm tested agian 3x and it passed. where would you suggest i go from here? thanks ahead of time... the crank sensor came with an alignment tool. i used it so i dont think thats it. the only code i got was 223... or 233... i cant remember now but when i looked it up it didnt seem to be the problem
