PastryLikeDood
I found a thread a while back about which spark plugs 3L's like best but could not find it again. If I remember correctly it was an Autolite plug?
No they don't. You can use regular copper plugs as long as you don't mind changing them every 20-30K miles. (I actually prefer to have a look at the plugs at least every 20K miles on an older engine, so copper plugs are just fine for me.)but they have to be double platinum.
SixFoFalcon - I thought there was an issue with the wasted spark design of the EDIS system on the 3.0 that required a double tipped plug?
Double plats are required on the EDIS because of the differentSixFoFalcon - I thought there was an issue with the wasted spark design of the EDIS system on the 3.0 that required a double tipped plug?
Although platinums may physically last for a 100,000 miles, it's been my experience that their performance falls off after 30,000 or so miles, so in my opinion there isn't all that much to be gained by running plats.Since plug tip erosion is greatly reduced with platinum, that's how
the vehicle mfgs reach the '100K miles before a tune-up is needed'
requirement......
Anyone using Autolite XP104s? They're on sale at a locally owned autoshop, from 7.50ea to 3.99.
