Spark plug replacement
Jake xadn
Callahan Fl.
06 , 2.3l . I bought the truck used . It has around 260,000 miles. Went to change the spark plugs , they do not want to come out without stripping. Any help will be appreciated.
not a good situation.
do the plugs rotate at all?
I would try some of the freezing penetrant oil and use lots of it.
let it sit overnight.
if the plugs move at all, work them back "n forth the smallest amount while penetrant is flooding the wells.
Get the truck up to temp and hit em with some pb
Sometimes just getting the engine warm to the touch can help. They can be frozen in place when the engine is stone cold but will break free once the engine is warmed up.
I’d definitely run the engine at least up to operating temp, then hit them with a penetrating lube, let it cool, drive it again, lube, cool, etc a couple times. It’s not always an option though. When possible, it’s the best option though. Sometimes a torch can help, but again not always possible. Working back and forth can help, if you can get them to move at all. My last misadventure had one snap off in the head, then despite a 4+ hour effort of working at it with a torch and lube and easy-out, I broke the easy-out, which then promptly refused to come out and also refused to shatter and then the head had to come off, which resulted in more broken bolts and parts and just really wasn’t a good time, but she runs good now so it was worth it and got me a freshened up top end so it wasn’t fun but it was worth it.
My preference for spray lube is Seafoam Deep Creep or some commercially only available stuff that I happen to have a case or two of yet. Probably going to try some Kroil soon since I’ve finally seen it locally and I’ve heard good things. PB Blaster has never impressed me other than making a decent bee spray for the junkyard. WD-40 is a useful product, but it’s not a penetrating lube.
Also, at least Autozone, and probably other parts stores have spark plug thread tools and stuff for fixing threads.
